Is gary going to stock NSK SH rails then or have I misinterpereted the 'S/H'?
I sent a message to the seller and got this:
So that's £70 for the 20mm or £60 for the 16mm. I may as well get the 20mm for the sake of £10. Are you saying these rails wont be any good quality? They're the same part numbers and dimensions as the ones at Zapp...they look the same as far as I can tell.Dear Jonathan,
2 SBR16-600mm supported rails +4 blocks:
92 usd
Air shipping cost is included.
2 SBR20-600mm supported rails +4 blocks
109 usd
Air shippping cost is included.
Thanks!
Chai
I've just looked at the 'HGR20' profile rail from Zapp. It comes to £129 for 2x600mm rails and only two blocks. I simply cannot afford to spend that much on rails!
There's a good set of 590mm listed, but still £135 plus the tax is too much. I don't wish to sound as if I'm neglecting all your good ideas purely due to cost, it's just even spending £70 on the Z-axis is a bit much for me but I can see that it's worth it to get supported rail!
I see, thanks for pointing that out to me! I'm still interested in the drilling option but it hardly seems worth it for the Z-axis now.
If I decided to use the supported round rail for the Y axis (or just round rail supported with the holes etc) is 16mm going to be sufficient or should I go for 20mm?
Also, how to I work out the optimal spacing for the rails on the Y axis? Is the torque from the Y screw a significant factor here since that would suggest I should put the rails close together?
Thanks again for all the advice - there certainly is a lot to think about!!Last edited by Jonathan; 22-08-2010 at 11:24 AM.
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
