21-08-2010 #11
Yes! I was thinking that just hadn't got round to posting it...I'll allmost certainly do that. Maybe have 75mm or 400mm travel. Thinking about it I may as well have the lower bearing with several positions - it's only a few more holes after all.
With regards to supporting the rail at the centre I could do this when the Z range is limited, as above. It would make it take slightly longer to change between the two set-ups though.
Just to clarify I'm not using actual I beam, just 3 aluminium bits slotted and bolted together to make an I. I can't find RHS in the right dimensions so I guess I'd have to use a similar approach, just now with two 6mm aluminium plates instead of one. I'm concious that using RHS is going to further increase the horizontal distance from the router to the Y axis. Would it be ok to cut the front out of the RHS (to make a C shape) just where the spindle mounts. It's either that or get big enough RHS to fit the spindle inside?
Unfortunately that's not the case otherwise yes, I would just use blocks. One project I have in mind which needs a long Z axis is making wind turbine blades. That would, or course, be wood I should be OK.
Thanks for the help. I'll have another look for what steel RHS I can get hold of and modify the drawing accordingly.
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
