  1. #8
    The machine I got from ebay has, from memory, 90mm Rhs, a 9mm wall and its welded (erw) and that has been milled for the rail mounting surface (I guess thats why they used 9mm to allow for the removed steel) this has only been done on one face so internal stress wouldnt have been a problem.
    Ali is also lighter, dosnt rust (not like steel anyway) and dosnt need painting
    Are you using the rails back to back on the y axis to counter the uneven load distribution? (ie 25% reduction at the open side) if so have you looked at doing the same with the zaxis? if you mounted them on a c channel (or box with a slot cut out, then you would have space for the Drive screw as well)
    Just a thought and is some thing I was looking at a while ago for an Ali box and supported round rail machine. Not enough hours in the day..........
  1. Box section tube straightness
    By jimbojones1000 in forum Metalwork Discussion
    Last Post: 18-02-2014, 04:11 PM
  2. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 05:29 PM
  3. Help with name of aluminium section plz
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 02-12-2012, 10:01 PM
  4. Aluminium box section
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 28-10-2012, 01:13 AM
  5. spindle cross section view
    By routercnc in forum Tool & Tooling Technology
    Last Post: 05-08-2011, 12:55 AM
