Thread: cnc machine stiffness calculator
24-08-2010 #9That makes me feel better, I thought I was just being lazy using FEA. :whistling: If you just want to calculate the K value and dont want full blown FEA then I tried this software and seemed very good. About £40 for a licence, if you go for it.[EDIT: Bit of research and it's not possible to calculate the torsion constant for arbitrary shapes since they are not symmetrical and will warp, leading to large errors. Only option is to use FEA (Finite Element Analysis) software.
or this is free working demo, cant save or print (think you can screen capture tho) aproximate k value but very quick for calculating composite beams.
sure paste it in, the spindle design bit has lead me to start at the cuuting tool so Im working on the feeds and speeds and required forces at the mo. so that should help as well.Ross, I think you can still contribute. You were working on a Z axis weights sheet - that could be useful to tab at the front of this one because at the moment the Z axis weight (or mass!) is a user estimate.
stiffness measurements cnc mk3
By routercnc in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 27-04-2014, 09:00 PM -
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
PCB Track Width Calculator
By irving2008 in forum General ElectronicsReplies: 0Last Post: 10-05-2013, 02:34 PM -
Resistor Calculator
By Lee Roberts in forum General ElectronicsReplies: 2Last Post: 17-04-2012, 05:22 AM -
Loading Calculator for Z axis
By Ross77 in forum Linear & Rotary MotionReplies: 7Last Post: 28-07-2010, 09:57 PM
