25-08-2010 #8
Ken,
Soft limits work from the tool zero point so so you have your zero located in the centre of the work which we will say is 100mm square but you can go 150mm in any direction before you run out of travel.
So set your work zero's at the centre, then go to Config > Homing and Limits and set the soft max in X and Y to 120 and min to minus 120, click OK and go back to the main screen and click on soft limits which is just below the DRO's to the right.
This now means it can only go 120mm in any direction before it stops on it's own.
One drawback with soft limits is that it's from work zero, move the origin point and you have to reset the limits.
.John S -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
Limit switches and Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 06-03-2013, 10:51 AM -
Mach3 + 2010 Screenset crashing. "Error found , Art Code: 9988"
By Mad Professor in forum Artsoft Mach (3 & 4)Replies: 34Last Post: 11-06-2012, 02:44 PM -
Strange issue with mach3 and limit switches! what could it be!!!!
By AdCNC in forum General ElectronicsReplies: 2Last Post: 21-04-2010, 09:50 PM
