24-08-2010 #1
Hello to all
I am a total newcomer to the Mach 3 and Lazycam programs, currently I have linked my router to Mach 3 and carried out a few trials. I found that I ned to be able to prevent a judder by stopping the gantree from overrunning the end points of the platform - have zeroed the software, but would like to know if there is a way of saving a configuration with the zero position and maximum limits for the machine held in it so they dont have to be put in each time.
Another question is that I have tried to use Lazycan to creat initial G-code, e.g. by typing a name then clicking the post g-code option, however when run in mach3 the gantree only seems to traceout a single letter (if that) what could I be doing wrong.
Any help appreciated :confused:
I have posted a small video on Yourtube of the current setup please let me know wta you think
http://www.youtube.com/watch?v=ya-089sPfEA
25-08-2010 #2
isn't thatwhat limit switches are for? do you have any on the CNC?
25-08-2010 #3
Are you using a fully licenced version of Mach?
If not you are limited to, I think 500 lines of code.
You can set up soft limits in Mach were you tell Mach the max travel for each axis, which will stop over travel without the need for limit switches.
andy
25-08-2010 #4
Thanks GeorgeD - No there are no limit switches on my CNC.
Thanks Audioandy the version of Mach3 is not a fully licenced version, however the run doesnt event get as far as 100 lines of code. Thanks for confirming the availability of software limits - I shall have to do a bit of digging to see where in the software they are set.
Ken
25-08-2010 #5
Your best bet is hardware shutdown rather than software,simply because if the computer crashes fo some reason?...well it goes without saying. :whistling:
25-08-2010 #6
Hi Ken
Look under Config Homing/limits
Andy
25-08-2010 #7
25-08-2010 #8
Ken,
Soft limits work from the tool zero point so so you have your zero located in the centre of the work which we will say is 100mm square but you can go 150mm in any direction before you run out of travel.
So set your work zero's at the centre, then go to Config > Homing and Limits and set the soft max in X and Y to 120 and min to minus 120, click OK and go back to the main screen and click on soft limits which is just below the DRO's to the right.
This now means it can only go 120mm in any direction before it stops on it's own.
One drawback with soft limits is that it's from work zero, move the origin point and you have to reset the limits.
.John S -
26-08-2010 #9
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
Limit switches and Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 06-03-2013, 10:51 AM -
Mach3 + 2010 Screenset crashing. "Error found , Art Code: 9988"
By Mad Professor in forum Artsoft Mach (3 & 4)Replies: 34Last Post: 11-06-2012, 02:44 PM -
Strange issue with mach3 and limit switches! what could it be!!!!
By AdCNC in forum General ElectronicsReplies: 2Last Post: 21-04-2010, 09:50 PM
