Thread: How-To: Feed Rate Calculation
Mr Lee: I am cutting composit door but every 2 or 3 door machine start chipping from top and bottom and some how tool broken advise me what type of bit do I use to get extremely fine cutting and bit last for a month at least as well
25-03-2020 #2
I would try a compression bit/cutter, their flute's have upcut and downcut spirals all on one cutter, so down shear cutting on the top of your material and an up shear cut on the bottom of the material.
You can also get spiral up only and spiral down only, the choice of cutters is great now days, so always select the best cutter for the job/operation.
Of course you need to be using the right speeds and feeds or it won't matter what cutter you use.Last edited by Lee Roberts; 25-03-2020 at 01:22 PM.
Feed and speed equation
By Bush Flyer in forum Spindles & Drive MotorsReplies: 7Last Post: 18-03-2014, 01:32 AM -
stepper acceleration rate - limits?
By dsc in forum Stepper & Servo MotorsReplies: 11Last Post: 02-03-2014, 02:25 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Vc & feed/rpm of the these tools on steel
By hoezap in forum Tool & Tooling TechnologyReplies: 2Last Post: 14-02-2013, 08:50 AM -
Router bit recommendation, spindle speed and feed rate?
By FlightCaseCo in forum Spindles & Drive MotorsReplies: 13Last Post: 03-04-2012, 12:53 PM
