Thread: How-To: Feed Rate Calculation
Depends on your definition of free.
The one I use the most is:
http://www.cnccookbook.com/CCGWizardv40.html
(Unless you count doing some quick mental arithmetic and guessing!)
His is good because it calculates tool deflection, so you can get a rough idea of the surface finish and how close the tool is to breaking. I also use that when trying new materials by adjusting the depth of cut until the tool deflection is at the value I know is safe for that cutter in a known material. For instance I know on my machine that with a 6mm single flute cutter it will run all day with 1.6um tool deflection in aluminium but if I exceed that the surface finish is worse. So a few days ago I tried cutting mild steel with the same cutter on the router. Adjusted the depth of cut to get a calculated 1.6um deflection then did a test cut at that feedrate and depth of cut. It worked well...much less messing about to find the optimum.Last edited by Jonathan; 30-01-2012 at 08:36 PM.
Feed and speed equation
By Bush Flyer in forum Spindles & Drive MotorsReplies: 7Last Post: 18-03-2014, 01:32 AM -
stepper acceleration rate - limits?
By dsc in forum Stepper & Servo MotorsReplies: 11Last Post: 02-03-2014, 02:25 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Vc & feed/rpm of the these tools on steel
By hoezap in forum Tool & Tooling TechnologyReplies: 2Last Post: 14-02-2013, 08:50 AM -
Router bit recommendation, spindle speed and feed rate?
By FlightCaseCo in forum Spindles & Drive MotorsReplies: 13Last Post: 03-04-2012, 12:53 PM
