Hi Andy,
If you mean the terms 'pocket' 'drilling' and 'profile' then they are as follows:
profile: this means to cut around the inside, outside, or on the line of a shape. For example, cutting a big hole out of something you need to set the profile depth to slightly more than the workpiece thickness (use a spoil board under the workpiece). For an 18mm workpiece I would set this to 19mm.
drilling: drilling a hole to a certain depth. You can also 'peck drill' where the drilling is done is stages, withdrawing the tool to clear swarf periodically
pocket: these are areas of flat recessed material, but not all the way through. For example, to countersink a hex bolt head you want a flat bottomed hole or 'pocket'. These can be any shape usually, but the s/ware above is asking about specific circle or rectangular shapes.
Does this help?
FOR SALE: Conect 121 CNC Lathe
By m_c in forum Items For SaleReplies: 5Last Post: 27-03-2014, 10:44 PM -
Feeds and speed guide/pocket book
By maritimesbob in forum Marketplace DiscussionReplies: 3Last Post: 10-11-2013, 09:38 AM -
Circular Pocket problem?
By Leadhead in forum Machine DiscussionReplies: 6Last Post: 03-10-2013, 01:05 PM -
conect 121 cnc
By minimad30 in forum Conect LathesReplies: 1Last Post: 31-07-2013, 11:07 PM -
More Conect Machinery
By leitzscope in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 09-04-2010, 10:09 PM
