Page 1 of 3 123 LastLast
    Ok, so I started aquiring 'machinery for the home' about 18 months ago....
    DIY CNC machine - check
    Mini-lathe- check
    PCB fabrication - check
    Injection moulding - dammit, I've gots to gets me one of those.
    Joking aside, I've now a burning ambition/need/want/blah blah to be able to make my own custom guitar pickup bobbins.
    "Why Hank, why - injection moulding is for grown ups?"
    Well, because nobody makes them in the size I need ...I presently make them out of acrylic on my CNC *but* even just making one bobbin, I end up with a beard like the guitarist in ZZ Top, so while my last beard was growing my mind began to percolate (never a good thing).
    So what are my options...
    1. Ask someone to make them for me .....pros - less hassle. cons - massive spondoolies. (for the mould)
    2. Ponder how I can make them at home. So my immediate thought was,of "does such a beast exist", well this is 2010 so yes it does....
    http://cgi.ebay.co.uk/Bench-Table-To...item35a7cd377f .
    but OUCH!
    I think I've seen manual ones elsewhere (which clamp to the bench & where the operator is the 'compression element' lol!) ...smaller cost, but still at least one British Kidney in payment.
    So I thought I'd throw this one out to the mycncuk 'massive'....what would you recommend?
    My requirements are... a plastic bobbin which looks something like this...
    http://ww.tinyurl.com/38jq75z (but to my own size - about 5mm long x 5mm high)
    Any clever ideas about how I could make them in quantity....or how I could get them made in quantity without having to force my wife to work down Commercial road?
    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    No idea about the bobins but here is a DIY Injection Moulding machine :)
    http://www.users.uswest.net/~kmaxon/...d_mach_137.htm
    Quote Originally Posted by ecat View Post
    Intersting link ....but *way* above my skills (or needs).
    this manual lever style is perhaps more of my accessibility level...
    http://replicatorinc.com/blog/2010/0...ction-molding/
    or if someone wants to go the "scrapyard challenge" route...
    http://www.youtube.com/watch?v=v8oRzCvGFbw
    it does make me wonder if I a standalone 1 axis (Z plane) CNC machine could be designed to do the compression aspect?
    Now there's a subject close to my heart :rofl:
    Here's a useful link...
    http://www.dms-diemould.co.uk/
    I started making an injection moulder because I didn't have room for the real thing in the garage. Then I suddenly got space and bought an old 25 ton Arburg, haven't plumbed it in to the 3 phase yet.
    The point being, I have most of a home brew, fully automatic injection moulder about 6 feet behind me. All hydraulic, opens closes, ejects, injects from a hot pot a la Travin, measures plastic in, heaters all wired up with a digital thermostat, plugs in to a paralell port for all the critical timings etc.
    I don't really want to sell it, but I can be arsed to finish it. If you are interested I am sure we can come to some arrangement :naughty:
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 61. Received thanks 10 times, giving thanks to others 9 times.
    Anyone tried DIY iinjection moulding with a glue gun ? I think you can get nylon and polyethylene glue gun rods:
    http://www.mutr.co.uk/index.php?cPath=56_19_57
    Aww I'd just finished typing a really long post then the webbrowser crashed :(.
    Anyway....take 2
    I've seen/used a 'manual' injection moulder at school. It requires a LOT of force to pull the lever to inject the plastic. As in hanging off the lever with my feet off the ground isn't enough (granted I was only about 15 at the time but you get the idea) .... so I'm not sure a Z-axis would be up to it. Then again you do get a huge mechanical advantage with a screw, but is it going to be fast enough? The machine you had a pot which you put the plastic pellets in, waited for it to melt... then squash so quite simple really. I could try and get a picture of it if you like?
    I think your main issue might be making the mould. There are only two moulds for the one at school - both made by the teacher. He told me they were difficult and took a long time to make, especially since he used the surface grinder on the mating faces of the two parts. I guess it could be easier to CNC mill the mould, but still something to consider.
    I don't mean to put you off, just thinking aloud that's all!
    R.E. Bobbin making.
    Couldn't you just cut them out of a sheet and use a T-slot cutter to do the undercutting? That way you could machine the lot in one go.....and tessellate lots onto a sheet of plastic.
  7. The Following User Says Thank You to Jonathan For This Useful Post:
  8. #7
    Tom's Avatar
    Lives in Nottingham, United Kingdom. Last Activity: 11-11-2023 Has been a member for 9-10 years. Has a total post count of 176. Referred 1 members to the community.
    Another little teaser here... :)
    http://www.cambam.co.uk/forum/index.php?topic=355.0
  9. #8
    Which Commercial road ?
    John S -
  10. #9
    i2i's Avatar
    funny you should mention a desktop stand alone plastic injection machine, i have the very same thing.
  11. #10
    Thanks for the mould mft link - Have you had a quote from them for a mould?
    Your injection mould - being 3 phase would be a problem (I'm low-fi here!)...I'm also envisagening an unfeasibly large contraption!?
    I guess most people aspire to a nicely finished mould (so no machine marks are visible on the end result) - but since these puppies will not be visible, I could probably accept a rough & ready one! I'm hearing that Aluminium loaded expoxy might be the route for the mould for my modest requirements.
    R.E. Bobbin making.
    That's a reasonable idea...I might ponder. It'd certainly make the beard a little bit shorter (more Rolf Harris than ZZ Top), but I'd still prefer unshaven (I'm talking beards here - right?). Also, a quick skeg on the net shows they might be a bit hard to find? (ok, so Argios probably isn't the best! -joke ok!). BTW that second link - he rocks, talk about understated....legend!
    Which Commercial road ?.
    C'mon, You know the one (psst: you never heard of tipping?)
    PS Not related to injection moulding at all, *but* hot off the press tonight - another 'machine for the home', after much trashing of plastic & flaying of switches & sensors - a 'direct to copper clad board' inkjet printer :-)
    Edit: Just seen your post...
    Quote Originally Posted by i2i View Post
    We need more details than that - a photo to prove it along with a scan of your driving license etc. Seriously...I need more details - I think I now need the opposite to viagra (flacidagra?)
  1. Plastic injection mold making forum?
    By gavztheouch in forum Moulding Machines
    Last Post: 13-10-2022, 11:31 AM
  2. New toy - Arburg injection moulder
    By Robin Hewitt in forum Moulding Machines
    Last Post: 26-10-2014, 11:59 PM
  3. Epoxy cast plastic injection tools
    Last Post: 27-01-2014, 11:33 PM
  4. RFQ: Any Injection Moulders on here, before I buy Chinese ?
    By Bazzer in forum Projects, Jobs & Requests
    Last Post: 18-05-2013, 11:25 AM
  5. Proxxon MF70 for making injection molds
    By forrest in forum Moulding Machines
    Last Post: 11-04-2012, 11:30 PM
