    Wonder if it is some kind of charge pump problem. This is a safety feature and needs to be either configured in the pins, or overriden on the board directly (to bypass).
    On my system this is pin 1 (port1). In the ports and pins menu, if you scroll down one of them lists the charge pump. In this table you need to add the pin and port required.
    As John has mentioned, if you know the pins required for this controller it would help with setting it up. Could you take the lid off and tell us the make of the parts inside? They are possibly off the shelf bits and will have pin outs listed.
ID:	2950Hope this helps.
  1. NEW MEMBER: From Oz - ex of Cardiff anf lost :P
    By Carlb1058 in forum New Member Introductions
    Last Post: 02-04-2013, 04:57 AM
  2. NEW MEMBER: Hello - total newbie!
    By eggsBenedict in forum New Member Introductions
    Last Post: 05-01-2013, 12:47 AM
  3. NEW MEMBER: Total noob about to embark on a build.
    By Wal in forum New Member Introductions
    Last Post: 21-12-2012, 02:48 AM
  4. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
  5. Total novice seeks advice on stepper motor drivers
    By R.Andersen in forum Motor Drivers & Controllers
    Last Post: 25-01-2012, 11:34 AM
