15-12-2010 #11haaha!!!! you read my mind this time :) iv already considered it, not really explored it deeply though, you would need a clever way to output the torque from your inside-out timing belt to your output shaftCould you use a timing belt inside the harmonic gearbox as the flexible gear thingy? Milling the inside out pulley would be fun. Probably do it in two semicircles...
the beautful thing about using a belt for the strain wave gear is its so flexble you could use two simple bearings or rollers for your wave generator and use a slightly larger timing belt for the outer gear and pre-load it with your simple two bearing wave generator....
im thinking it would take quite a bit of elegance to make it work... backlash might well be very small but with heavy cuts im thinking it will have quite a bit of give
errrrr..... i dunno ??? youve got me thinking on the issue again.... if i try to fit any more in my head i think one of my eyes might pop out :)
Edit: not sure why you would need to cut the internal in two halfs ?? i dont think you would need sharp corners at the root end of the pitchLast edited by blackburn mark; 16-12-2010 at 12:17 AM.
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
