Page 15 of 15 FirstFirst ... 5131415
  1. #141
    What size fly cutter do you use for surfacing yours?
    It's a special that someone made for me and it's widest is 60mm.
    I seem to be able to cut 3mm per pass with the 6mm single flute cutter now :)
    Yep surprising how much a nice solid bed changes how the machine performs and best of all it never changes it's shape when you put your cup coffee near it.!!
  2. #142
    Quote Originally Posted by CLaNZeR View Post
    Very, VERY impressive.
    Not really, anyone can put a big pulley on the stepper motor and lower the acceleration to get a high feedrate at the expense of resolution. Such a high feedrate would only make a negligible difference to machining time on a router used mainly for cutting metals. It's just for show...
  3. #143
    Jonathan,
    A quick question about your "box" type Y-carriage in this pic please... Particularly about the position in which the horizontal plates are bolted to the vertical plates....
    The top plate is bolted slightly above the top of the vertical plates and the bottom plate is bolted slightly below the bottom of the vertical plates... If that makes sense.
    Did you do this for a specific reason such as making the initial DIY build/squaring easier?
    Cheers,
    Andy
  4. #144
    Quote Originally Posted by WandrinAndy View Post
    Yeah I ordered the wrong size aluminium plate!
    To make it easier to square you should mill a shallow slot into the back of the Y-carriage plate which holds the Z-axis bearings. This can then align to one of the smaller plates on the Y-axis to get Z perpendicular to Y. You can just about see what I mean in this picture, circled in red:
Name:	DSC08939 (Medium).JPG
    Which reminds me I never posted the pictures from when I changed the Z round rails to linear guides:
Name:	DSC08940 (Medium).JPG
ID:	7065Click image for larger version.
Name:	DSC08933 (Medium).JPG
ID:	7061Click image for larger version.
Name:	DSC08935 (Medium).JPG
ID:	7062Click image for larger version.
Name:	DSC08938 (Medium).JPG
    Using the indicator made aligning the rails properly and getting it to run smoothly trivial. Fitting everything in the small available space was less trivial. Hard to say how much difference it made to the performance of the machine, since at the time the MDF bed was the limiting factor and I think my spindle might be on it's last elbows...
  5. The Following 2 Users Say Thank You to Jonathan For This Useful Post:
  6. #145
    I finally had chance to drill the array of M8 holes for clamping in my router bed. Here's the result:
Name:	DSC00050 (Medium).JPG
ID:	7457Click image for larger version.
Name:	DSC00056 (Medium).JPG
ID:	7458Click image for larger version.
Name:	DSC00068 (Medium).JPG
    I used a carbide drill since the spindle speed required for a 6.8mm HSS drill is too low for the spindle to have enough torque to cut efficiently, if at all. I ran the drill at 9500rpm and 840mm/min with flood coolant, which according to the manufacturer's recommendations is quite conservative, but still plenty fast enough. I didn't see any point pushing it harder as that would only increase wear on the spindle bearings.
    Here's a video showing the process. Possibly the most repetitive video I've uploaded to youtube so far...
    The Z-axis motor, not surprisingly, got pretty toasty but other than that it went well. I had to move the bed out to reach the whole length, so it's currently 360mm from the normal position. Just need to make the router cut a drain in it, then I'll put it back.
  7. #146
    Forgot to say in the previous post...
    Around the edge of the aluminium bed I've put 3x2", 1/4" thick aluminium angle. This acts as a barrier for the coolant, so to ensure it seals I put a strip of 1.5mm thick neoprene under each piece. I used my metal cutting bandsaw to cut the 45° angles, but the finish from this although not bad for a bandsaw, is still quite rough.
Name:	DSC09876 (Medium).JPG
ID:	7469Click image for larger version.
Name:	DSC09877 (Medium).JPG
ID:	7470Click image for larger version.
Name:	DSC09879 (Medium).JPG
    Bit of an unusual set-up on the lathe so I videoed it:
    (Something wrong with the sound on the past two videos)
  8. #147
    Hello, looks like you've got a fine machine there Jonathan! Good work, It inspired me to go the way with the bed-box-gantry type mill, if I get started with one on my own.
    Usage: pcb, wood, plastic engraving, possibly some easy metals, maybe 3d printing?, 3d scanning? Bigger polystyrene works. I like the idea of the adjustable bed height for different jobs. I already have three industrial dc motors+encoders and two ballscrews I was planning to use. I was thinking of a machine capable of moving 800*700*300mm.
    A couple of questions came to mind:
    1. Where do you get all parts? Is there a standard online place with good prices/service? Guides, ballscrew, bearings. Saw that Hong kong was mentioned.
    2. I was thinking of moving the gantry with two rotating ballscrews and one motor. Long
    gearbelt to sync the screws and have the motor directly on one screw. Whats your thought about this? I think I'm ok with a 1/10 or 1/20 mm milling accuracy. (I don't think I can build the complete works with greater tolerance)
    /Ola
  9. #148
    Quote Originally Posted by olalofberg View Post
    So just about everything!
    800*700*300mm.
    That size is very manageable, although you will have to make it quite strong to make good use of the large Z-travel. Are you sure you need that much? I guess it's for the 'bigger polystyrene works', in which case since you will use an adjustable height bed, the required rigidity is lower.
    The nearest you'll find to a cheap standard online place is the seller linearmotionbearings2008 on eBay. Many people on this forum have used him, myself included, and been pleased with the products and service. It works out cheaper to get the spindle from other eBay sellers, or even better ali-express.
    6 of one half a dozen..
    If you use two motors the available torque is greater, so you should get higher acceleration and top speed, however it will work out a bit more expensive than one motor and a long belt. I don't consider one motor stalling and the gantry racking a valid concern since if your machine is tuned properly, and you shouldn't be running it if it isn't, then that should never happen. On my machine I had little choice since with the current gantry design it's impractical to route a timing belt to link both rotating nuts.
    Not difficult.
    In other news, I have made and installed the drain for the router bed so I've been cutting with flood coolant. I fount that one corner of the machine is ever so slightly lower than the rest, so I put the drain in that corner so the coolant flows. A week later I discovered the reason for this corner being lower - there's a crack in the floor and it's sunk down!
    The drain is fairly basic, just two parts I made on the lathe to hold some fine mesh, which is easily replaced:
Name:	DSC00094 (Medium).JPG
ID:	7571Click image for larger version.
Name:	DSC00273 (Medium).JPG
ID:	7572Click image for larger version.
Name:	DSC00274 (Medium).JPG
ID:	7573Click image for larger version.
Name:	DSC00275 (Medium).JPG
ID:	7574Click image for larger version.
Name:	DSC00276 (Medium).JPG
    After running for some time:
Name:	DSC00086 (Medium).JPG
    Video of cutting with flood coolant:
  10. #149
    Did you source or mill the aluminum support for the guide rail?
    Thanks, Jeromy
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
