    Some more photos ...
    This is how the gantry fits together.
    Detail of gantry sides. I've milled them flat etc. Unfortunately I drilled those 5 holes (for M8 bolts) in exactly the same place on both sides, forgetting that the other one is flipped over! Looks like I'm going to have to mill those 5 holes on one side to move them across by 6.5mm...dow!
    Just after milling block to fix box section to gantry sides:
    It fits!
    Pretty accurate too I sawed the plate to roughly 80x80mm then used a 20mm 4 flute endmill to cut it to size. I used 2mm cut depth and 1000mm/min - no problem at all! I'm sure I could have gone faster or cut deeper since it didn't get hot. I then did a single finishing pass taking off 0.2mm at full 20mm depth and 300mm/min.
    I'm very pleased with the accuracy seeing as this is with trapezoidal screws and using backlash compensation. I guess the brand new cutter and having set the backlash compensation values to the nearest 0.002mm a few days ago helped.
    Shiny :)
    Just a shame I didn't measure the box section beforehand and relied on the sellers dimensions. Turns out it's more like 74.6mm, not 74. I think it'll be ok though...
    I'll post a vid of that latest bit of milling when I've compiled it.
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
