21-12-2010 #11
Splendid!!!! im surprised how fast its cutting
thats a lot better than i would have thought :)0.06mm
i had to try your scientific test, im getting about 0.03mm but i only have 120mm cutting space so your gantry sides were a good choice over plate
i removed the drive from one side (in order to find the one that was stalling/binding) and it ran better on a single stepper than it did on both which i found pretty bizzarYes one X motor is much stiffer than the other. It's limiting my feedrate...
i could only think that there was some kind of sympathetic (machanical) interference between the two with there being more drag on one side and because i was lazy when i fitted the the standard brearings (the fit is to tight) i cant back the pre-load off... the diffrence in drag between each side isnt massive but im hoping that its that causing the problems
my double row A/C bearings have turned up so ill give them a try at some point but for now ill stick with 1500mm/min
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
