14-06-2011 #11
I got the steel on Wednesday. Adey Steel were very organised and helpful. They cut the steel to the lengths I specified. They did accidently not give the offcuts from cutting my steel that I requested, so I went back and got it plus they gave me some box section free of charge along with some 6mm plate to practice welding with!! I'll use some of the extra box section to make the frame stronger if required..
Since then I have used my metal bandsaw to cut the box section - it's cutting very close to square now. I'm currently drilling lots of holes in it which will be used to support the bed at different heights. I intend to motorise the bed, effectively making it an F axis, to minimise the overhang of the Z-axis for each job.
I've ordered the ballscrews for X and Y (RM2510 and RM1610) - the tracking says they should arrive in one week, so my aim is to have the frame done by then.
The basic shape of the frame is going to be the same as in post #113, with a few extra pieces to strengthen it. The front is 'missing' to allow the Z axis to protrude past it at the end of the travel. I've used 50mm and 60mm, 3mm thick box section and 120x60mm, 3.6mm rectangular in places where I wanted a bit more strength.
Here's a couple of photos:
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
