    Jonathan
    Reading more and more post I find my self thinking o's##T what have I let my self in for
    I really thought 20 mm rails for the bed would be more than ample to carry the weight of the whole cnc machine
    two 20 mm rails (made from 304 stainless steel) and four bearings mounted on the 90 degree side of 40/80 profile aluminium extrusion
    and a centre ball screw (centre of the bed) 0f 16 to 20 threaded bar
    where on earth do you all get your aluminium from as I have ordered of ebay, it arrived today so bent it is unusable
    James & Luke
    Quote Originally Posted by luke11cnc View Post
    They will be ample to carry the weight since each of the 20mm bearings is rated for about 880N. That's not as excessive as it might seems though, see what I posted here:
    http://www.mycncuk.com/forums/showth...near-bearings-...
    The reason I advised using the bigger bearings is not directly due to the higher load ratings. It it because they have 5 rows of ball bearings, not 4. This seems to make them have a lot less play than the <=20mm bearings. So I'm not saying you have to get the 25mm bearings, just that it will probably be better if you do.
    where on earth do you all get your aluminium from as I have ordered off ebay, it arrived today so bent it is unusable
    I now use http://www.aluminiumwarehouse.co.uk/
    Only issue with them is you have to buy 2000mm lengths. If there's something smaller you need let me know as I might have a bit...
    What size did you buy out of interest, and who from so I don't make the same mistake?
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
