    Quote Originally Posted by TrickyCNC View Post
    Very nice machine you have there Jonathan
    Thanks, but it's not that great really...quite a few things I'll be changing as the gantry is not strong enough for what I want to do next.
    did you get anywhere with the 'twisted bearing' screw drive setup ?
    Yes, I mounted it and it worked well with low backlash:
    http://www.mycncuk.com/forums/router...html#post16838
    It's clearly not as good as a real ball-screw, but as something to get started it's excellent due to the low backlash and very low friction.
    I cut the first piece with the new bed last night - just a pocket in the back of an aluminium motor mount and the finish was much better than with the [edit] MDF bed and I didn't need to do a finishing pass to get that.
    TrickyCNC's Avatar
    Location unknown. TrickyCNC Last Activity: Has a total post count of n/a. Referred 6693 members to the community.
    I saw you have mounted it, what I could not tell from reading the rest of the thread, is if you kept it / still use it ? and if so, how it was holding up ?
    Rich
    I used it for quite a long time, until changing to an RM1610 ballscrew. It was working well, although had caused some wear to the M16 rod (although not enough to be a problem) due to bearing inner ring being significantly harder than the screw, however I think if you used springs to push the angled bearing against the screw and/or used a trapezoidal lead-screw instead then it would last a long time.
    I cut the first piece with the new bed last night - just a pocket in the back of an aluminium motor mount and the finish was much better than with the aluminium bed and I didn't need to do a finishing pass to get that.
    Surely that should read MDF bed.?
    Yes, thanks for pointing that out - fixed.
    What size fly cutter do you use for surfacing yours?
    I'm cutting the aluminium angle now to fit round the sides for the coolant barrier, then once I've got the bed aligned I'll get the router to cut a suitable hole in the bed at one end for the coolant to flow through and make a filter etc...
    I seem to be able to cut 3mm per pass with the 6mm single flute cutter now :)
    It's a special that someone made for me and it's widest is 60mm.
    Yep surprising how much a nice solid bed changes how the machine performs and best of all it never changes it's shape when you put your cup coffee near it.!!
There are currently 21 users browsing this thread. (0 members and 21 guests)
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
