17-12-2010 #11
Surely a timing belt for the outer gear would have the wrong profile.
Maybe we are talking on cross purposes. I suppose it depends on the timing belt you choose. If it's one with round teeth then you could CNC mill it easily without a 4th axis. If it's say XL then you'll want to mill it with a 4th axis, but clearly the chuck will collide with the other side of the pulley when it's milling the teeth, unless you did it in two halves...or more realistically thirds.
Finished all machining for router this morning! *Just* needs assembling - waiting on my dad to put some bigger legs under it since the previous arrangement was designed for a 10kg gantry, not >50kg!
Been thinking about how I can clamp stuff to the bed to machine it. It would be nice to have T slots like on my milling machine since then I could use the same clamps and easily put the vice/rotary table etc on it. I do have some HSS T slot cutters however I think cutting MDF will destroy them.
My plan is to buy two sheets of 18mm MDF. Glue/screw one down to the bed, get the router to cut the wider part of the T in that and level it, then put another sheet of MDF on top of that and cut the top of the T slot. That way I can use standard router bits...My only worry is if MDF is going to be strong enough?
Just been making collets for the cheap router I'm using. I'll post a video here soon...
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
