17-12-2010 #11
Can you think of anything better to use that's not too expensive? Maybe plywood, but I guess that's not much better. Vacuum table isn't much good for metals. Bear in mind it needs to be about 800x1900mm ... so clearly I can't afford a nice piece of tooling plate that size!
I'm not sure about the epoxy idea either, wouldn't it just crack/crush?
Making collets for router:
http://www.youtube.com/watch?v=m98fPg-_vUU
Not quite sure with what you mean by exiting the belt through the outer wall, diagram?
I agree buying one is probably the safest option! If you're after a really big reduction then perhaps several timing belts and pulleys could work. If each one gives 1:4 (feasible I think) then you only need 2 belts to get close to 50:1. Timing belts don't have backlash, but I'm not sure about stretching. Why do you want such a high ratio anyway? My rotary table is 1:90 and it takes forever to rotate, even with the 70v stepper drivers.Last edited by Jonathan; 17-12-2010 at 01:11 PM.
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
