  1. #10
    What have you done there? Can you give some more detail
    Er, not much more to say really? Standard thin section bearing with bore bigger than the thread (20mm here, but more would be better to get less axial load on the bearing) placed on the thread at an angle. I'll use a strong spring to pull the bearing against the thread so that it rides over any imperfections. That's what the tabs are for on the mount, to mount the spring.
Name:	wonky bearing drive.png
    I'm toying with the idea of pressing a brass insert into the bearing lathed to better fit the 60° thread profile. It's tricky to work out the exact dimensions though...
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
