08-09-2010 #11
Yes I spotted that. There's two threads, one quite short one about the method I'm using and one huge thread about roller screws which is another story entirely. I may well try making a roller screw if this method doesn't turn out so well.
These photos wore taken yesterday:
Pretty self explanatory - Z-rails are bolted down and really smooth.
I milled the alu plate square at school, shiny! Never seen such a good finish on aluminium - must be the grade.
Today I've milled the gantry sides flat at either end and drilled them. Also had to nip a few mm off the end of one of the Z rails. I was a bit worried with it being hardened, but it milled OK taking small cuts. Plenty of smoke...
Also started machining the M16 rod for the Y axis.
I'll post some more photos tonight.
routercnc:
I see what you mean with the bearing jumping now - that is a bit of a worry.
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
