  1. #14
    Quote Originally Posted by FatFreddie View Post
    What were they quoting for runout? I was looking at some that were quoting ten times better than that - just wondering how reliable the claims are.
    Yes mine was indeed quoted at ten times better than than.
    I've decided to make a welded steel frame for my router. This is my initial design:
Name:	CNC Router 3b.jpg
    I will probably add a few more triangles to that, however I'd like to keep the front of the machine open.
    In that drawing I've discarded the tall gantry sides and replaced it with a bit of 100x60x3.6mm steel box section, so now the 'gantry' is only 100mm tall, not several hundered mm. This should help with the stiffness.
    Also I am intending to have the existing bed fit inside the frame and attach it to the 6 vertical pieces with a series of holes which will allow the bed to be raised and lowered depending on the size of the job. Most of the time I will have it as close as it will go to the gantry, giving only 100mm (ish) z-travel. I've not yet needed more than this so I think it's a good way of stiffening up the machine without compromising on working volume. It'll also gain a good bit of travel on the Y axis.
  1. NEW MEMBER: new member building a cnc router
  3. Building a hybrid CNC mill. Need advice and recommendations
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
