Quote Originally Posted by chip View Post
i,ll have to have one of those spindle mounts off you soon,when i get round to changing my z plates.
Excellent ... I'm hoping I'll be able to mill them on the router when it's done as that should be quicker, or at least easier, than milling them. I would still bore the 80mm hole on the lathe. I will also round off the two corners that look a bit thin.
Name:	DSC07627 (Medium).JPG
Name:	80mm x 125 spindle mount.jpg
I've just drilled fixing holes in the 100x60 box section for the bed jacking screw mounts. I just need to drill some more holes for the X axis ballscrew mounts and chamfer quite a few of the ends then the main frame is ready to weld.
