1000th post
So here's a video showing my router doing 1000mm/s (2362ipm) on the Y-axis:
http://www.youtube.com/watch?v=k3MG7...=youtube_gdata
All I did was change the pulley to 42T so the pitch of the screw is effectively 35mm. It's well above the critical speed of the screw, but interestingly it seems fine.
The video also shows the rotating ballnuts going happily at 15000mm/min.Last edited by Jonathan; 15-09-2011 at 07:24 PM.
19-09-2011 #2
04-10-2012 #3
Jonathan,
A quick question about your "box" type Y-carriage in this pic please... Particularly about the position in which the horizontal plates are bolted to the vertical plates....
The top plate is bolted slightly above the top of the vertical plates and the bottom plate is bolted slightly below the bottom of the vertical plates... If that makes sense.
Did you do this for a specific reason such as making the initial DIY build/squaring easier?
Cheers,
Andy
04-10-2012 #4
Yeah I ordered the wrong size aluminium plate!
To make it easier to square you should mill a shallow slot into the back of the Y-carriage plate which holds the Z-axis bearings. This can then align to one of the smaller plates on the Y-axis to get Z perpendicular to Y. You can just about see what I mean in this picture, circled in red:
Which reminds me I never posted the pictures from when I changed the Z round rails to linear guides:
Using the indicator made aligning the rails properly and getting it to run smoothly trivial. Fitting everything in the small available space was less trivial. Hard to say how much difference it made to the performance of the machine, since at the time the MDF bed was the limiting factor and I think my spindle might be on it's last elbows...
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
29-09-2012 #5
Not really, anyone can put a big pulley on the stepper motor and lower the acceleration to get a high feedrate at the expense of resolution. Such a high feedrate would only make a negligible difference to machining time on a router used mainly for cutting metals. It's just for show...
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
FOR SALE: CNC Router/Mill
By cimbian in forum Items For SaleReplies: 19Last Post: 25-09-2012, 01:10 PM
