Thread: DIY mill...
  1. Hi Mr Monkey
    Sorry I did not reply, As u can see from my other posts I milled the cheap Chinese table I bought with a 1 inch hinge cutter after I had covered it with wood. Making 4 PCBs at a time cutter depth must be the same at extremities.
    Yoy will see from my other posts I have made a Gingery horizontal mill impersonation. Its a lot of heavy ironwork bolted together. There was a guy on here asking about distortion in a welded frame. Well I dont weld everything first off. Bolts can be sufficient but if something starts to move clagg a weld on it. Good reason for using steel bits.
    Wishing u success with ur build Keith
  2. Click image for larger version.
ID:	25113Click image for larger version.
ID:	25114 Just to show how u can make an adapter block for cheap Chines router table to drill and machine small parts. The spare collet holders are dirt cheap together with sets of er11 collets to 7mm. I drilled a 6mm brass rod and made a nozzle for hot air soldering iron. the cast iron block was made on my big lathe.
    Best regards Keith
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
