Thread: DIY mill...
08-08-2008 #13
The program doesnt do chip load or other machining calculations. It is a general purpose framework analysis. The estimation of forces on the cutting tip which give rise to the twisting moments that cause the frame to distort is not an easy one.
A 500W motor (approx 0.75HP output) at 32000rpm gives .17Nm torque, so the max cutting force before the motor stalls on a 4mm cutter is .17/.002 = 85N, however it probably wouldnt get close to that in reality.
Another way to look at it is the cutting force = chip size x chip removal energy = h * w * E
where E = power * tool efficiency / volume removal rate
Aluminium requires about 0.6W per mm3 so a 300W output motor will only acheive a removal rate of 180mm3/sec
E = 300 * .75/1.8e-7= 16.7e6 and therefore force for a .5mm deep cut on a 4mm endmill is around 16.7e6 *.0005 *.002 = 16.7N
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
