Thread: Plasma table 2m x 1m
Amen to that !
22-09-2008 #2
Bit of a delay designing the circuitry. Decided the best place for the CPU was at the cutting head. Close connects for the Y and Z axis controls and switches. Reasonably close connects for the X axis stepper controls and end stop.
Decided to use fibre optic links for the computer connection so I don't have to worrry about interference from the torch.
The Z axis is screw driven by a zippy 24 volt DC motor with brake and 4 bit control on the speed.
The motor has a chopper disc to show where it is.. Rather than waste cpu time oversampling to read the chopper I decided to put it on an interrupt. Here's my cicuit. If either chopper optic changes the the cpu interrupt goes low until I read the data on the input pins.
I'll let you know if it works
09-10-2008 #3
Circuits done, pcb's made, thought I'd start with the fibre optic link because I've never done one of those before :D
Set up a full duplex terminal so anything I typed on the keyboard had to go out around 5 metres of cable as light before it showed on the screen. Worked a treat.
That's a letter 'i' on the 'scope, on it's way back from the optic at 9600 baud. Can't ask for cleaner than that.
Now I know I can upload programs for testin', next comes some steppin' :D
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
BUILD LOG: 4' x 4' plasma table build in Canada
By 190-v8 in forum DIY Plasma Build LogsReplies: 2Last Post: 02-02-2014, 01:19 AM -
10' x 5' Plasma table design
By Kerryfisher in forum Plasma Table MachinesReplies: 4Last Post: 20-02-2013, 09:28 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
