Thread: Router Cutters
On the subject of clamping and t-slots. A cheaper and easier to replace solution is a sheet of 12mm MDF, drilled out with 5mm or 6mm holes in a grid (easy job for the CNC machine!), then hammer in some matching size t-nuts from the reverse. They're cheap and when you've accidentally ploughed the baseboard you simply hammer them out and replace the board...
The Following User Says Thank You to irving2008 For This Useful Post:
11-09-2010 #2
Thanks for the cutter info John, unfortunately I spent much more than just the cutters.
Oh well!
It's only money!
Peter
12-09-2010 #3
John,
Forgive my ignorance but the cutters you have suggested are completely different to those i've seen and used before.
I have had access to an AXYZ router that used end mills and ball mills etc that looked more like drill bits (cutweltools.co.uk do good examples for around £5.00) and I would be greatfull if you could educate me as to the difference.
These milling cutters are twin, 3 and multi flutes. Therefore I am now confused.
V Bit Cutters in Aluminium?
By Washout in forum Tool & Tooling TechnologyReplies: 3Last Post: 06-03-2014, 03:29 PM -
TCT Router cutters in a mill running at 4000 RPM
By suesi34e in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-02-2014, 08:02 PM -
Looooooong Cutters
By GMCNC in forum Tool & Tooling TechnologyReplies: 6Last Post: 02-05-2012, 12:54 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM -
Cutters for alu and mdf
By Tom in forum Tool & Tooling TechnologyReplies: 0Last Post: 16-11-2009, 10:26 PM
