Thread: Router Cutters
Milling cutters are for Aluminium,Brass,Perspex,ect,ect....if you're cutting MDF then a Straight flute wood router bit is what you need.
13-09-2010 #2
been using carbide mill ends and ball nose cutters to cut soft woods ,hardwoods and mdf , with better results than straight flute router bits the spiral flutes clear the cut as they go
spiral cut router bits are also very good, they are to all effects a mill end
14-09-2010 #3
Do you know any good suppliers of carbide end mills in the UK? They need to be 1/8" shank and have a ring collar. I have been using Drill Bit City http://drillcity.stores.yahoo.net/endmills1.html in the US, these have been great cutters, and these guys have a great selection, but the postage is so expensive.
Would like to find a recommended supplier in the UK.
Regards,
Tom
V Bit Cutters in Aluminium?
By Washout in forum Tool & Tooling TechnologyReplies: 3Last Post: 06-03-2014, 03:29 PM -
TCT Router cutters in a mill running at 4000 RPM
By suesi34e in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-02-2014, 08:02 PM -
Looooooong Cutters
By GMCNC in forum Tool & Tooling TechnologyReplies: 6Last Post: 02-05-2012, 12:54 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM -
Cutters for alu and mdf
By Tom in forum Tool & Tooling TechnologyReplies: 0Last Post: 16-11-2009, 10:26 PM
