there is nothing intrinisically wrong with long lead screws as long as they are correctly supported in tension by appropriate supports and of sufficient diameter. Making them larger pitch reduces the revs needed which also alleviate whipping. The issue then becomes one of inertia; a long, thick screw has high inertia needing lots of torque to accelerate it, but again that can be offset by a larger pitch...
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
