I believe that whip occurs when the shaft rotation speed equals the natural bending frequency. So a ballscrew with a 20Hz nat frequency would whip at 1200rpm (=20 Hz[cycles per second] x 60 seconds per minute).
Natural frequency is related to SQRT(k/m) where k is stiffness and m is mass. Therefore in principle a hollow ballscrew, with slightly lower stiffness, but much lower mass, would give a high frequency and could rev higher before whipping, all else being equal. It would also have a slightly lower inertia, allowing slightly higher accelerations etc.
But never seen a hollow ballscrew, so either they are rare, or not worth the expense.
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
