Thread: CNC Design and advice
17-09-2010 #2
How much travel are you hoping to have on the Z-axis? I think the spacing of the linear bearings on the Z axis looks a bit close at the moment. I'd extend those triangular pieces on the side of the Z-axis up to the top of that sheet - it should stiffen it a lot. If you don't then I think that the sheet of MDF will flex too much, resulting in poor accuracy.
What pitch screws are you intending to use? You'll struggle to get a good feedrate with those motors on only 24v. Their inductance is too high. They work well on 70V though...
Here's a drawing in solid edge of the motor you're using...might find it useful! You should be able to open it in solid works, if not let me know and I'll convert it.
Astrosyn 1Nm Size23.zip
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM -
