I assume the problem is false stops, and Mach3 trips out when the plasma starts up?
My mk1 router machine had a similar problem (steppers interfered with limits), and I disconnected the limit/home cables one at a time to track it down. The longest cable (z axis home) caused the problem on mine. For mk2 all cables are now shielded, the shields all run to a common earth at one end only (star pattern?), and the cable runs for motor and limits are in seperate energy chains on either LH or RH side of the machine. I've a bit more work to do before firing it all up, but hopefully this will solve my problem.
I'll also experiment with 0.1uF capacitors across the limit terminals on the control board if I still have problems.
Any of this applicable to your machine?
HF start plasma and CNC...
By Davek0974 in forum Plasma Table MachinesReplies: 12Last Post: 04-06-2020, 11:57 PM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
cnc plasma cutter problems
By oadamo in forum General DiscussionReplies: 8Last Post: 21-06-2011, 09:28 PM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
