Thread: Pipe thread in 22 tpi???
20-09-2010 #1
"Could you just fix the leak under the sink?"
It's the "just" bit that is so annoying. The problem is a platic pipe fitting with 2 tiny holes in it. It's on the boiling water tap so it probably didn't like the temperature.
I can remake it in brass but WTF is the thread
It's the same diameter as a 1/4" BSP but near as I can measure 22tpi.
If it isn't BSP of NPT or Threadform or 14mm ISO, WTF is it?
Anyone got a clue 'cause I haven't :whistling:
WANTED: 150mm dia x 15mm wall Ali pipe
By r0bsk1 in forum Items WantedReplies: 9Last Post: 12-06-2014, 04:19 PM -
3mtr CNC pipe profiling machine.
By D-man in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 23-08-2013, 08:49 PM -
Flexible Stainless Steel pipe that holds its shape?
By Fivetide in forum Marketplace DiscussionReplies: 15Last Post: 14-02-2013, 07:35 PM -
RFQ: Looking for someone to design and build me a cnc pipe router/cutter
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 01:59 PM -
your ideas on a pipe profiling machine
By D-man in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 03-11-2010, 05:09 PM
