23-09-2010 #9
£28 for 1 x 7201 bearing...!!
I should try looking elsewhere, should be paying no more than £2.50-£7.00 each depending where you get them from and the quality you are after. You will not need anything that's high quality as the speed that it will be working at and the forces involved will both be quite low compared to what the bearing specs are.
If ringing round then ask for the Chinese bearing prices, they should be more than good enough for what you will be using them for.
And there is always fleabay.... http://cgi.ebay.co.uk/7201-SINGLE-RO...item2eab04d5bb
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
wobble / wiggle on ballscrew double row angular contact bearing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 14-12-2013, 08:35 PM -
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
Using SBR12 as ballscrew end support
By Lovre in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 13-12-2012, 08:52 PM -
I need some help, Dukitec FK15 support unt - torque of the nut onto the ballscrew
By range3rrr in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 09-04-2012, 11:20 AM
