Thread: Axis resolution advice
True Robin, I think Cam is confusing resolution with accuracy. To be accurate to 0.1mm you need to resolve to something better, 0.05mm being an obvious one, ideally better than that. For a router cutting wood, 0.2mm is probably accuracy enough, needing 0.1 or better resolution. You'll never be as accurate as the lowest resolution you can maintain. So if you want 0.05mm accuracy then you need a 1/2step of 0.025mm or better. However that is just the accuracy of the drive train. Once you allow for backlash, flex of the supporting environment (even without cutting forces the mechanics will flex as they move), etc. your accuracy will suffer...
For a model wing rib, 0.25mm accuracy should be good enough, so 1/2 step resolution to 0.05mm plus some flex allowance should get you close...
23-09-2010 #2
This is exactly what I was driving at, I just missed the terminology by a mile. To re-phrase I wanted to know what sort of ratio you give between resolution and desired accuracy. From what you are saying double is OK a little more is better (5x), but a lot more (x10?) will be lost in the machine.
When I posted I was thinking an order or magnitude, i.e. 10 fold between the two but back then I was also considering microstepping. That said although my understanding has improved very considerably my gear ratio is going to be very similar, rather good luck ! This because I have reduced to considering half stepping as the smallest finite usable resolution, but also lowered my resolution to accuracy ratio.
I have looked in to other peoples machines which is probably why I ended up at more or less the right ratio even if it was for the wrong reasons. I just wanted to check they had done there homework correctly, no point copying a bad design :)
For the record the machine will be ally, hopefully quite rigid, no unsupported rail, a router was only and after thought it will primarily be a laser cutter so no cutting loads.
Thanks for all the help, very useful.
CONVERSION: Round Column Mill Conversion - Looking for advice on Z-axis
By cnc-joe in forum Conversion Build LogsReplies: 0Last Post: 06-10-2013, 01:22 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Question on Micro step resolution?
By Ross77 in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 12-02-2013, 04:08 AM -
z axis rack and pinion advice
By marbles in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-01-2013, 11:41 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
