Thread: Axis resolution advice
This is exactly what I was driving at, I just missed the terminology by a mile. To re-phrase I wanted to know what sort of ratio you give between resolution and desired accuracy. From what you are saying double is OK a little more is better (5x), but a lot more (x10?) will be lost in the machine.
When I posted I was thinking an order or magnitude, i.e. 10 fold between the two but back then I was also considering microstepping. That said although my understanding has improved very considerably my gear ratio is going to be very similar, rather good luck ! This because I have reduced to considering half stepping as the smallest finite usable resolution, but also lowered my resolution to accuracy ratio.
I have looked in to other peoples machines which is probably why I ended up at more or less the right ratio even if it was for the wrong reasons. I just wanted to check they had done there homework correctly, no point copying a bad design :)
For the record the machine will be ally, hopefully quite rigid, no unsupported rail, a router was only and after thought it will primarily be a laser cutter so no cutting loads.
Thanks for all the help, very useful.
CONVERSION: Round Column Mill Conversion - Looking for advice on Z-axis
By cnc-joe in forum Conversion Build LogsReplies: 0Last Post: 06-10-2013, 01:22 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Question on Micro step resolution?
By Ross77 in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 12-02-2013, 04:08 AM -
z axis rack and pinion advice
By marbles in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-01-2013, 11:41 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
