Thread: Level Y Axis
26-09-2010 #1
Gents,
Now that me machine is running, not 100% but running I thought I would check how level it is. It was suggested that I purchase a DTI clock which I did and began to check the Y Axis. The following was noted and I would be greatful of feedback comment.
I have installed 4x80x40 alu sections to help stiffen/support my sacrificial bed. The supports are at 170mm ctrs so I check at these settings.
0, 170, 340 and 510mm ctrs
0=0 in the DTI clock.
170mm on the Y = 1.36mm
340mm on the Y = 1.48mm
510mm on the Y = 0.75mm
If I were to level 0 and 510mm this would still leave 170 and 340 out. I am assuming that the supporting Y rails are deflecting causing the readings above.
Im a total novice to CNC but work within Architecture therefore undertand some things.
Any guidance would be apprecaited. Who ever said that having a hobby CNC would be easy.
Entry level Probe
By Leadhead in forum Probing, Digitizing & ScaningReplies: 5Last Post: 09-10-2013, 07:55 AM -
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
setting the lathe up perfectly level on floor, really?
By onecut in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 25-06-2012, 05:11 PM -
Which end mill to level my acrylic bed?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 18Last Post: 03-02-2012, 02:57 PM -
NEW MEMBER: Just joined, hobby level
By cncgcg in forum New Member IntroductionsReplies: 12Last Post: 03-12-2011, 02:32 PM
