Thread: Mill with digital scales
21-08-2008 #11
Robin,
Have you seen this thread on CNCZone discussing PIC-based DRO capbility using cheap chinese scales?
regards,
Irving...
21-08-2008 #12
I guess, seeing as you posted there tonight, the answer is now yes :)
21-08-2008 #13
Absolutely, thanks for the heads up :D
I'm not sure he isn't introducing too many delays, that scale data gets very stale very quickly. I suppose it all depends on what he is trying to achieve.
I made the data input, scale reading and motor stepping completely interrupt driven. There is a sort of housekeeping program that looks for new devices and button presses, but all the vital stuff happens automatically in the background without the slightest intervention apart from Pause and Abort. It's as close to real time as I can possibly make it. I find PC's are a bit too handy at turning the interupts off.
22-08-2008 #14
Using a PC for anything truly real-time is hard - actually its not the PC of course, but Windows that is the issue. There are good real-time extensions for Linux and there used to be a pretty good real-time extension for Windows too but I don't know what happened to it - http://www.directinsight.co.uk/produ...urcom/rtx.html is something similar though. I've done projects in the past with single board and single chip solutions with tiny real-time kernels such as iRMX, embedded Linux as well as solutions based on WindowsCE, stuff you couldn't begin to make work reliably under Windows.
22-08-2008 #15
Tell me about it. My current stepper driver works under DOS so I can get my sticky fingers on the timer interrupt. Fortunately SVGA screen drivers are available or it would have to be VGA. It does everything in straight lines. I call the routine with a new x,y,z then idle away the time painting the screen until it gets there.
The new driver will run under XP. Every command is single byte until tool change when I upload tables. The little computer will buffer up to 32k so I should be able to keep ahead even when XP goes on vacation.
Digital angle gauge
By njhussey in forum Tool & Tooling TechnologyReplies: 4Last Post: 04-12-2012, 08:07 PM -
FOR SALE: DRO + 4 Scales
By Rikk in forum Items For SaleReplies: 0Last Post: 22-10-2011, 09:41 AM -
Digital drivers from Zap
By Simon C in forum Motor Drivers & ControllersReplies: 5Last Post: 31-03-2011, 03:27 PM -
FOR SALE: digital vernier.
By i2i in forum Items For SaleReplies: 8Last Post: 13-08-2010, 11:31 AM -
Reading and fixing Chinese scales
By irving2008 in forum Tool & Tooling TechnologyReplies: 26Last Post: 24-02-2010, 10:35 PM
