Thread: ISEL Ball nut
Hi Guys thanks for all the replys, yeah thats right lee it is dicy, sooner go elsewhere, last time i placed an order there i wated months and no goods.
Yes john s i have split the nut, i split the end off throught the ring where the dust seal sits, but i have clamped it back into the housing using a pinch bolt on one of the grooves in outer body, workuing for now, so i will save my money.
Hi i2i yes this is a concern, matching up nuts to ballscrews, a slight tolerance could be the diferance between working or not, to be honist i think swoping out the whole screw and nut in one go would be preferable, but then on the other hand ballnuts always come loose with a ball retainer inserted inside, and i cannot believe the supplyer test fits each but on your screw beforesellinf so there should not be a problem.....one hopes.
Hi ecat thanks for the link i will give them a shout
Anyway my fault for fitting too high power motors, if i had of left the smaller obsolete moters fitted then they would have simply stalled.
Moral here is to fit a small link in socket that will act on ES circuit should the plug fall out
Roger
SOLD: Various small CNC machines - ISEL/Unimatic
By badgerman in forum Items For SaleReplies: 14Last Post: 22-01-2020, 09:58 PM -
WANTED: Isel router wanted
By j.c.freeman in forum Items WantedReplies: 0Last Post: 29-05-2014, 12:20 PM -
what spindle should i buy for an isel fb2 machine?
By nobby in forum Machine DiscussionReplies: 3Last Post: 27-06-2013, 03:38 PM -
ISEL GFM 4433/ educam 44
By macomk in forum Machine DiscussionReplies: 0Last Post: 18-06-2013, 10:01 PM -
FOR SALE: isel gfm 4433
By plotter in forum Items For SaleReplies: 1Last Post: 09-10-2012, 06:00 PM
