Thread: (Mini Lathe)Potecting Leadscrew
28-09-2010 #1
How are those shields fitted and what material is used to protect the leadscrew from swarf? I've protected the saddle gears by using a perspex plate over the back of the saddle where swarf seems to accumulate terribly but the leadscrew needs a cover now.
Stripped the machine right down to the bare metal used a dremmel to remove the bad casting spikes on the inner of the bed and removed rust that was primed over in the factory(Really bad/poor steel used on these lathes castings) repainted it with metal paint and it looks really nice now.
Also done a bearing change and changed the puny little 3 jaw self centering chuck for a 100mm 4 jaw independant chuck.
:whistling:Last edited by GeorgeD; 28-09-2010 at 03:45 PM.
28-09-2010 #2
Hi George,
I don't know about your leadscrews specifically, but bellows arrangements (commercial and homemade) might be an option for you to keep swarf out:
http://www.youtube.com/watch?v=EV-eH...eature=related
28-09-2010 #3
How do RCNC.
Nope,that wouldn't do,ye see the saddles carrige has two items in the way ie the gear that tracks along the rack and then the half nuts to engage with the leadscrew for auto feed.
I'm stumped as to how it works?
7th pic down shows the protection,although this saddles apron is different to the C2/C3....
http://www.toolsandmods.com/apron.html
28-09-2010 #4
And howits doneonthe SC2....
28-09-2010 #5
Ah,Ive sussed how to do it but I need 1" diameter 5" long springs? anyone know whereto get these?
Put flax cloth around springs,feed the springs on to the leadscrew either side of the apron and thats it. :)
28-09-2010 #6
the clue, George, is in the text... "spring type leadscrew covers " These are some form of wound spring steel or maybe plastic strip with the outer attached to the saddle and the inner end attached to the leadscrew bearing block, possibly on some form of swivel...
like these
let us know the price when you find out...
28-09-2010 #7
The leadscrew is 16mm and these are 16mm :-(
http://cgi.ebay.co.uk/66300-HOT-BODI...item5889f42ca0
These will do but the price will not...I only need two,not 16 :-(
http://cgi.ebay.co.uk/86764-HPI-SHOC...item5889fc27bf
The tension looks about right? can't have it too stiff,could cause a problem on the autofeed?
28-09-2010 #8
Will give this a try.....washing machine waste outlet pipe,this is plastic over spring ...just might be what the doctor ordered and is the right diameter?
28-09-2010 #9
28-09-2010 #10This iswhere your needle and cotton(darning skill)comes in handy...you make socks for the springs.errr... but these have holes....
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
Mini CNC lathe builders
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 28-07-2010, 10:00 AM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM -
A Mini Lathe
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 03-05-2010, 04:11 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM
