Thread: Boxford 190vmc upgrade
i2i - you've' got me a bit interested. I've had a chat with Boxford and they can't sell me the software unless I'm an educational establishment, which I am not. All this stuff probably went in the bin instead of staying with the mill so unless I can get it running easily (i.e. with EasyCNC or Freemill, neither of which I've tried yet!) I'm going to have to change the control system. So can you advise if Mach3 will handle the following:
1/ Stepper motor indexing tool carousel, valve or motor for clamping and unclamping the tool and programmed sequence to move the spindle to the holder, drop the tool, raise the spindle and then rotate the carousel, drop and reclamp. I ask as I'm going to have to make a carousel as the Boxford one is pneumatic and I don't want to go that route.
2/ interface to DC level speed control for spindle? I know about the parallel port signals for the steppers but how do you drive the spindle?
3/ I need to engrave windows TTFs, with borders and simple line graphics, do you know if there is software available to do this?
Sorry about the list, but I need to be sure I make the right choice, it seems much more complicated driving a mill than a lathe because I need the engraving.
TIA
David
WANTED: Boxford 190VMC toolholders, tool changer and manuals
By davethesteam in forum Items WantedReplies: 5Last Post: 06-11-2017, 11:29 AM -
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM -
BUILD LOG: Time for mk2 upgrade!
By routercnc in forum DIY Router Build LogsReplies: 16Last Post: 26-02-2011, 11:38 PM
