Thread: Boxford 190vmc upgrade
Hi attached are photos of a board attached to the Lenze with connections (which I assumed was doing the job similar to the 107 board ), I assume I should by pass this board and wire straight into the Lenze. I have also attached a photo showing the side of the Lenze with it's connections. The Lenze I have is the 534.
20-10-2015 #2
No if I remember correctly from helping Keith with his lathe this board is where you connect the 0-10V and Run signal from pmdx 107. Those 4 wires on the right are 0 & 10V and the + & - Enable for Run.
The Direction is changed by the Relay swaping the polarity of the DC spindle so you control this using the Dir relay on the 107.
Edit: Just be aware you will need to set Mach3 up so there is a pause for spindle to come to halt before reversing output is set other wise damage will be done.Last edited by JAZZCNC; 20-10-2015 at 06:20 PM.
20-10-2015 #3
Are you talking about the green board?
If so the connections on the right read look to read 10v, 5 (i assume volt), 0v, -10v. For some reason the machine was originally wired up using only the 5v and 0v connections. The bottom two wires are black/red for 240v ac. The Lenze seems to have a seperate 240v supply.
21-10-2015 #4
Yes the green board.
It's not unusual for some speed controlers to use 0-5V and the Pmdx 107 has this feature if required. However It's more common to use 0-10V.
The Lenze controller can obviously use either.
Agnd on pmdx 107 goes to 0v and Aout to 10V. By default the 107 outputs 0-10v so If you want to use 5V the set the Dip switches on the 107 board to output 5v.
If you want to test this with crude setup then put a 1.5Vdc battery between 0v and 10v. (Or 0-5v spindle will just spin faster thats all)
Then find the enable pins and put a NO switch on them to toggle ON/OFF.
(Warning don't do any of this wiring live has the speed controller could be at mains potential)Last edited by JAZZCNC; 21-10-2015 at 08:37 AM.
21-10-2015 #5
Yes that all makes perfect sense now. I assume I can use a relay for the NO switch, and for that I maybe best going to the Mach3 forum for advice on how to set this up in mach3. I shall have a go at setting it all up this evening. Will let you know how I get on.
Thank you very much for your help with this.
Steve
21-10-2015 #6
Well depends on how your doing it.? My suggestion below was just for a quick test to prove you have the right connections, which I'm 95% sure is correct.
But if your going to wire it properly then you already have the NO Relay built into the 107 board. That's the purpose of it and it works in conjunction with the Spindle speed.
Setting up in Mach3 is easy enough and you can actually download from PMDX Mach3 XML file which sets it up for you. If you have any trouble here come back and I'll guide you thru setting up mach3.
21-10-2015 #7
Hello,
Delayed (sorry) reply to Steve, and anyone else who is interested. I have the manual for the Lenze drive if it's of any use. I also have some other documentation including a wiring diagram and user manual. If anyone is interested I'll put some stuff on my FTP site so it can be downloaded.
You should be able to run the drive with a 10K pot and a switch to see if it works. The terminals have 10V control and ground available but as stated on previous post this lot could be (NB - manual implies it is) at mains potential so be careful!
I have got nowhere with mine, lots of work has come in, enough to last til Christmas. I'll get there one day. :-)
David
WANTED: Boxford 190VMC toolholders, tool changer and manuals
By davethesteam in forum Items WantedReplies: 5Last Post: 06-11-2017, 11:29 AM -
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM -
BUILD LOG: Time for mk2 upgrade!
By routercnc in forum DIY Router Build LogsReplies: 16Last Post: 26-02-2011, 11:38 PM
