Thread: Boxford 190vmc upgrade
20-10-2015 #19
No if I remember correctly from helping Keith with his lathe this board is where you connect the 0-10V and Run signal from pmdx 107. Those 4 wires on the right are 0 & 10V and the + & - Enable for Run.
The Direction is changed by the Relay swaping the polarity of the DC spindle so you control this using the Dir relay on the 107.
Edit: Just be aware you will need to set Mach3 up so there is a pause for spindle to come to halt before reversing output is set other wise damage will be done.Last edited by JAZZCNC; 20-10-2015 at 06:20 PM.
WANTED: Boxford 190VMC toolholders, tool changer and manuals
By davethesteam in forum Items WantedReplies: 5Last Post: 06-11-2017, 11:29 AM -
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM -
BUILD LOG: Time for mk2 upgrade!
By routercnc in forum DIY Router Build LogsReplies: 16Last Post: 26-02-2011, 11:38 PM
