It's for Videography, so smooth motion is imperative. I'll be mounting HD video camera with a pan/tilt fluid head which means there will potentially be some other forces at play during movement. No need for a stepper motor with precise control, just something that allows variable speed of movement ranging from very slow to perhaps ~5cm per second at the top end.
At the moment I'm using a manual push system using a ball bushing carriage on an extruded aluminium extrusion - this doesn't lend itself to consistent, repeatable results.
Perhaps I should try some SS rod from B&Q as a sort of proof of concept, but I assume 10 or 12mm trapezoidal leadscrew and nut would give far superior motion in terms of smoothness. Even a ballscrew is not out of discussion, although I'd prefer spending as little as possible for the results I'm after.
VLast edited by Vikash; 06-10-2010 at 09:34 AM.
02-10-2010 #2
Got a feeling that gear&rack will be the smoothest for this along with speed and slow tracking into the bargain.
The rackis the dearest component but willbe a lot better choice for me over leadscrew.
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
Minimum PC requirements
By manofgresley in forum Computer HardwareReplies: 2Last Post: 26-10-2013, 04:33 PM -
Accuracy Problem
By richie00boy in forum Machine DiscussionReplies: 12Last Post: 09-09-2013, 11:24 AM -
Machine bed accuracy
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 03-11-2010, 11:24 AM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
