    Hi
    This is my conversion of a Amadeal AMA 25LV Mill
    Strip down remove the spindle motor and electronics,there is to be a more powerful spindle motor fitted
    Motor and electronics removed
    Spindle head removed
    Clean out gear box and remove gears as these will be no good for the new motor they are plastic and would not take the strain
    Next remove spindle machine an extender for the new spindle drive,the gear you see is also to be machined for the drive of the spindle
    Extender now welded to the gear chain bearing fitted ready for the housing
    Fitted
    Spindle Head back on but at this pint i find out the spindle wont turn (ouch ) so strip down to find the problem i had drifted the spindle two far in and locked up the bearings so drift it out 1/32 fitted it back and all is well always make sure the bearings turn before assembling not like me im always in a hurry and this is what happens
    Onto the lathe to machine the adapter for the motor i had intended to direct drive the spindle by this adapter but then i read that the Colett must have the long bolt that go’s throw the spindle to hold the Colett i was hoping the colett would stay in place by just knocking it into the taper, so after machining i had to go back to my original plan that is to gear drive it and that is where i am at the moment, gear machined and connecter partly re machined for the spindle.
    Next up date next week i hope
    Thanks for looking
    Stuart
    Hi Stuart,
    I appreciate this thread is quite old but wondered if you had anymore updates on your build?
    I recently bought the same AMA25LV and I am in the process of converting the mill to cnc.
    I'm also starting a conversion on a AMA25 as well.... Any pics and information would be great. Looks good so far
    salve chi mi aiuta mi serve il motore della ama25lv 600w non so dove trovarlo
    hi who helps me I need the motor of the ama25lv 600w I don't know where to find it
  1. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  2. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  3. Best all round mill/router? Vertical mill or gantry router?
  4. CNC Fusion Kit for Warco mini mill / Amadeal XJ12-300
    By rnr107 in forum Gantry/Router Machines & Building
    Last Post: 03-07-2012, 01:18 PM
  5. X3 Vs AMD 25LV (Weiss WMD 25LV) for CNC conversion
    By sebring115 in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2011, 12:20 PM
