    In my junk pile I have a Borries engraver. Has precise X Y screws at the top and a T slot bed at the bottom. There's a handle to wind the top up and down. It's old, 60cm high 33cm wide by 34cm deep (approx) and weighs like it would need collecting. Comes with a big controller box and a stack of manuals. Presume the pneumatic engraving heads could be replaced with a light rotary cutter but not by me.
    I'm getting too old to do anything with it. Looks too useful to throw away, might be just what some budding CNC hack on a budget might want. Forty quid.
    If anyones interested I'll post some pics.
    Robin
  2. put some pics up Robin...lets have a look
    I think the active area is only 100mm square, but as it's designed to drag a stationary carbide tipped cutter through metal with great precision, it is Robust. I think the steppers are rated 70v 6A. Full X Y bellows so it shouldn't have too many spiders inside :D
    Could be great for cutting pcb's.
ID:	57   Click image for larger version.
    Made in 1996, there's a plate on the back :D
    That would make a good little weekender!, are you going to do it up ?
    Did you ever get this going?
  1. CONVERSION: Hacking a Roland CAMM3 PNC-3000
    By Robin Hewitt in forum Conversion Build Logs
    Last Post: 22-09-2024, 08:55 AM
  2. NEW MEMBER: Yorkshire based modding / hacking noob says hello
    By dynamis_dk in forum New Member Introductions
    Last Post: 27-02-2014, 11:03 PM
  3. Cheap prototype PCB’s
    By Fivetide in forum Electronic Project Building
    Last Post: 17-11-2013, 05:22 PM
  4. Cheap Idea for a DRO
    By 1113562 in forum General Electronics
    Last Post: 27-02-2011, 04:20 PM
  5. NEW MEMBER: Cheap DRO using a USB interface
    By andyvail in forum New Member Introductions
    Last Post: 17-12-2010, 06:10 PM
