What type of mill are you using? Vertical, horizontal, or universal?
If you're using a vertical mill, then the DTI in the foreground of your DTIHolder1 pic can be used in an ordinary 3 jaw drill chuck (assuming you have one) and is a sufficiently quick and accurate way of clocking a vice for example, or other work with a reasonably smooth datum edge - just don't, whatever you do, overtighten the chuck (I've seen people do all kinds of silly things like that). The chuck only needs a light grip on the clock holder.
If you are using a horizontal mill (ie, where the drive arbor / spindle lies horizontally), then a plunger type DTI on a magnetic base may be a better option (clamp the magnet to the machine body, with the plunger on the workpiece / vice parallel etc.
Hope that helps, just yell if you need clearer explanation, and I'll get back to you.
WANTED: Boxford Threading Dial
By Raymond in forum Items WantedReplies: 5Last Post: 07-06-2014, 01:37 PM -
Help with Supply Indicator Lights
By GTJim in forum General ElectronicsReplies: 7Last Post: 03-09-2013, 08:49 PM -
Dial Gauge Vs. Dial Test Indicator?
By cncJim in forum Tool & Tooling TechnologyReplies: 4Last Post: 24-06-2013, 01:09 PM -
Co axial centering indicator
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 13Last Post: 03-02-2012, 07:49 PM -
eBay: 2GB USB Flash Memory, Swivel Stick (black)
By Lee Roberts in forum Items On eBay UKReplies: 1Last Post: 17-12-2008, 05:34 PM
