Thread: how to convert a mill to cnc?
Ok, i dont mind if its slow, dont think i can free up the table anymore. I dont know how much a servo system would cost, so dont know about budget. I thourght they were a lot more so dont know anything about them.
What type of Miller?
Bill
26-10-2010 #3
Hi, ive got a thiel 158 tollroom mill. Ive seen this kit http://www.rhonmac-cnc.co.uk/index.htm and woundered if the one with the 5.8nm steppers would be enough to power it geared down 2:1, but dont quite understand about the driver, as it appears to me that it can run 4.2 amp but the motor takes 7?
I used to have a couple of Thiel 158's, excellent machines. I remember the X axis being nice and free flowing, but the Y axis was always stiff. The Y axis is created by an overarm coming forward and backward with the spindle is attached, this all added to the weight and stiffness. Have you thought how you will get the stepper/servo drive to the Y axis? I am assuming you have a fixed table and not the XY fancy one.
Mike
28-10-2010 #5
Hi, i have the fixed one i think, its the same as the one that you attached a pic of. The y axis is surprisingly free moving with little backlash but can see how it could be hard to move. My x axis is the one that is harder to move and also has a bit of backlash so i need to find a way to reduce that first.
I have now reduced the backlash in my mill to 5 thou from 10, but dont know what an aceptable level is, so is this too much or will it do?
ThanksLast edited by speedhound; 30-10-2010 at 08:00 PM.
Convert Sketchup drawings to CNC ?
By DaveEP in forum SketchupReplies: 16Last Post: 25-08-2018, 05:52 PM -
What may be the best way to convert my Denford compact router to mach 3?
By suesi34e in forum Denford RoutersReplies: 34Last Post: 28-03-2017, 08:24 AM -
convert traditional machine or build router?
By Henrik in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-03-2013, 08:49 AM -
RFQ: Convert/update my Triac cnc mill
By sopysnipe01 in forum Projects, Jobs & RequestsReplies: 0Last Post: 09-04-2010, 12:31 PM -
Convert Wood Lathe from hand held tooling
By Wobblybootie in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 14-02-2010, 11:53 AM
